4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
I read about putting slots up, but not in Gm manual i can find??? Heres mine coming out of holder, slots down..... i believe its original from factory as this thing was parked in 1977 and barn stored since. So do i put slots down or up tomorrow?
https://postimg.cc/gallery/2y4dwtrk6/
Heres whats left of the rear mounts.
https://postimg.cc/gallery/1zeu31zgm/
Fig 20 in the manual, shows the "slots" up. The cross section is not too tough to see. Thanks to the Old Online Chevy Manual Project.
Steve H
I noted that some time ago, with all the details in that illustration, slots weren't indicated with arrows or text like everything else was. I don't think it makes a difference so i put my slots down. Thanks 4 bring it up.
Moderator, Electrical Bay
Years ago I removed one I know had never been changed (this being around 1975 or so) and the slots were facing down. I made myself a note of it since it differed from the shop manual and that's how I've done it since. Just be certain to use the right washers on the bottom side since larger ones can stop all movement and you don't want that.
~ Jon
Right!, i changed my originals with new, they are sae's and mine were badly battered, hammered and been through the wringer!
Must be alot of forces in action down there.
re; Hammered center bolt washers.
Heres a photo of the 1's i took out, i believe they're original to day built. The od measures rch more than 13/16". Remember these nuts & bolts are tight to 7/16 nft torque specs. They are not compressing the mount rubber like the outboard bolts are. Outboard bolts are snug tight only.
washers, https://postimg.cc/gallery/2a2hxsvnq/
We sent a man to the moon. Some of those guys probably worked on a Stovebolt truck or two.
Why can't someone come up with a simple design, modern material motor mount?!
