0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
Other than jacking engine up 3/4", whats the rest of the procedure? This question prolly needs to be answered buy some one who actually done it. thanks for any help.
I’ve done it. It’s easier that you think. I made a U shaped 3/4” plywood “pad” to fit around the oil pan so I was pushing on the bolt part of the oil pan not the pan itself.
Be sure to replace the mount cover too. The bolt on the driver side was tight coming out. Just lift the motor just enough to remove the bolts and use a Jack you know won’t slip. Could be a real finger smasher.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
Old thread about replacing motor mounts in '54 3104.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=825049#Post825049
Same basic info with a correction about the "thick" washer:
https://www.stovebolt.com/ubbthread...610/re-front-motor-mount.html#Post974610
Lonnie
- Lonnie
My '54 3104
thanks.
