Other than jacking engine up 3/4", whats the rest of the procedure? This question prolly needs to be answered buy some one who actually done it. thanks for any help.
I’ve done it. It’s easier that you think. I made a U shaped 3/4” plywood “pad” to fit around the oil pan so I was pushing on the bolt part of the oil pan not the pan itself.
Be sure to replace the mount cover too. The bolt on the driver side was tight coming out. Just lift the motor just enough to remove the bolts and use a Jack you know won’t slip. Could be a real finger smasher.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
- Lonnie My '54 3104 Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt.
