4 members (Hotrod Lincoln, artinva, Bill Hanlon, Opelika Tom), 67 guests, and 2 robots.
Topics128,078
Posts1,055,935
Members48,430
Hello all, wondering if anyone has revived their old linoleum covered floor. I have been thinking of applying vinyl over it or just cleaning up and staining
Not looking to pull the body off to replace floor
1949 Chevrolet 3100 Suburban Carryall
"Bad Guy"
More pix in Photobucket
1950 Chevrolet 3100 3-Window
More pix on Photobucket
1966 GMC Suburban Carryall Custom
"Big Guy"
"Bad Guy"
"Big Guy"
Regarding Battleship Linoleum, and, any linoleum sold in most of the USA:
Only "thin" linoleum is normally sold in the USA, including the linoleum sold by "Battleship Linoleum".
Thicker, original gauge, linoleum used in/over the Suburban's rear-floor/rear-plywood is often/sometimes available in Canada (and is mostly manufactured in Scotland).
You can, of course use the thinner linoleum, but, a purist might want to "router" the original grooves in it.
If I am incorrect (out of date) with this statement/information, please let us know your source of the appropriate thickness of black/brown linoleum?
Also, if anyone sets up a "jig" for routing the linoleum, and you are willing to do this for other members (at a price, of course), feel free to post that information here (it is within "forum rules", because you would be listing a service available more than once).
Suburban Lou,
Answer to your first post:
About 18 years ago:
I heat-gun-scraped the old linoleum off my Suburban's rear floor.
This took many hours, and many well-chosen-words, and many beers.
After making a paper pattern (for the overall perimeter, and for all of the holes for the seat-base-clamps), I cut a piece of black linoleum from Battleship Linoleum and laid it out on the floor (paint the perimeter of the plywood to match the linoleum.
Please note that the linoleum sheet has to be wider than 48".
It looks good - only one of us might know that it is not the appearance of the original floor (which had grooved linoleum).
Every 3-4 years, I check with linoleum sellers the North America for thicker linoleum. I have not found any, yet.
Hello all
I think we missed my original question
Can the old linoleum floor be stained?
"Bad Guy"
"Big Guy"
Yes, you could put vinyl over it (you'll need to make a pattern for cut-outs).
Yes, you could try staining the existing/original linoleum.
Thank you Tim
"Bad Guy"
"Big Guy"
