1 members (Gray_Ghost),
77
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | So I thru my dust caps away... Now I can't find any replacements. They are 2 1/4" in dia. I've looked for days. Does anyone know where to buy these?????
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Temporarily, you can use the bottom half of a Coke can for a dust cap- - - -it's just exactly the right size to be a snug fit over the hub snout. It also screams "RAT ROD" from about 50 feet away! A (Budweiser can is even better!) Jerry
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Thanks Jerry, Just got some Bud. I'll try it. Buy the way they actually measure 2.403
Julian Carter
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Once I measured them correctly. I find them a lot easier to locate.
Julian Carter
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Can you share where, and or part numbers? | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Gracious Won't this thread just die. Measured the hole correctly 2.403 is what I measured. After looking for something slightly bigger than that. I found several venders. It was easier than I was making it. Searching with a digital measurement was what made it simple.
Julian Carter
