6 members (Hotrod Lincoln, Oswald, 1955 1 Series, Gdads51, Peggy M, 1 invisible), 119 guests, and 2 robots.
Topics128,089
Posts1,056,352
Members48,442
Junior Member
Junior Member
I have slipped and have a new project, 1937 1 1/2 ton, I will need to remove and stabalize some surface rust on the body panels, will it be workable to sand to bright metal and then use a chemical treatment before a primer? this will be a rough stabalization/ restoration, not a full frame off...Any thoughts? Cheers
Anonymous
Unregistered
Anonymous
Unregistered
Welcome to the bolt.
I would not recommend the sandblasting if the panels are basically flat as there is a very good chance they would warp leaving you with more troubles than you now have.
I would suggest getting some discs like these http://www.abrasives4sale.com/strip-clean.htm
which can be used on an angle grinder to remove your surface rust and old paint.
Once that process is complete I would treat the panels with a rust converter such as Rust-Mort or similar.
Follow that by a coat of epoxy primer on which you can either paint or perform additional body work depending on your desired results.
Enjoy your project and send in some pictures. We like seeing other people's challenges/efforts.
Ex Hall Monitor
Ex Hall Monitor
T Online: Content
I wire brushed/sanded mine before treating. It's working OK so far.
For a first class job I think it best to use a chemical paint stripper and a DA sander on what you can reach, then gently sand blast all the rest and the deep rust the sander would not remove. The reason for not blasting everything is to reduce warping, as it takes a very skilled, or a very slow, blaster operator to not ruin a panel. This info I picked up while working at an antique auto restoration shop who does very high quality restorations.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Junior Member
Junior Member
Thanks gents, I was inclined to keep it in house anyway, so we will sand away and treat, followed by epoxy primer, then filler if I cant resist...cheers.
If you aren't going to remove the body from the frame and don't want to mess with the drivetrain, don't sandblast it, as you will never get the grit out of the mechanical parts.
Paint & Body Shop moderator
Sand blasting degrades the metal, however if you can find some one who is using plastic media it works very well but donesn't degrade the metal.
