Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Wickedbass, HandyAndy, Rusty Rod), 55 guests, and 2 robots.
Topics128,009
Posts1,055,291
Members48,419
#1283552 10/14/2018 4:41 AM
Having converted my 6v 50 Chevy to 12v I understand that I need to use a ballast to reduce the voltage to protect the coil and points from burning out once the truck is running. My question is how do I wire the ballast resistor in? The 50 Chevy has a foot starter. When the key is on, 12 v goes to the + terminal of the coil.
jameschevypu50 #1283553 10/14/2018 5:03 AM
The ballast resister should be located somewhere on the wire going into the positive side of the coil.
Chris
jameschevypu50 #1283611 10/14/2018 7:35 PM
V
VEW Offline
V Offline
You need to wire it so that 12v goes to the coil during start, and after starting, when your key goes to the on/run position you have voltage going to the coil through your ballast resistor.
~ Victor
1957 3100 - moved on
jameschevypu50 #1285426 10/30/2018 3:34 AM
Detroit,
If he has a stock ‘50, there is no start and run. He should have a stomp start and a run/ off at the key. If I remember correctly, there are 3 terminals on the back side of key switch. I think they were power in, accessories, and the run wire going to the coil. The ballast should be somewhere between the key switch and positive Side on the coil.
The stomp starter should have the positive battery cable connected as the “starter wire”, otherwise my 51 doesn’t have a “starter wire” stock that I know of.
Sorry if I use wrong terminology or verbiage.
Chris
jameschevypu50 #1285428 10/30/2018 3:41 AM
You're right, ndkid275. I forgot. blush
Thanks for taking the time to correct me. Sometimes I wish there was a "delete post" button.
For times like these. :grrr:
Thanks again!
--Chris
'64 Chev C20 LWB stepside (Ol'Blue)
jameschevypu50 #1285429 10/30/2018 3:49 AM
No worries, I’m not a smart man, but I did get to fix my wiring more than once AND I burnt up a few too many coils before the idiot light came on in my head that my ballast resistor was not in the truck!
Ops! All good!
Have a good night.
Chris
jameschevypu50 #1285430 10/30/2018 3:52 AM
The foot start switch for 12 volt applications (55-62) has a small side terminal that bypasses the ballast resistor during starting. Rock Auto has those switches in stock and they're a bolt-on replacement on the 6V starter, which can still be used when the 12V conversion is done.
jameschevypu50 #1285432 10/30/2018 4:05 AM
Thanks Jerry! I forgot about that!
