1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
Hi Guys,
I'm about to buy new wheels and tires for my 1954 modified Chevy 3100.
To give you a little background info, from what the previous owner has told me years ago, it has an older Camaro rear-end, TH350 transmission, and I know it has a 350 SBC engine. It has the original front end springs and axel and height, however, it does have disc brakes and power steering. Currently I have 15"X7" wheels and 215 tires(tight on the tie-rod end side 3/4" but never a rub). I am looking to buy the Cragar SS Direct Drill (5 X 4 3/4 studs) . After researching and doing my homework on measuring for offset and backspace(3 major tire dealers would not assist), I'm pretty sure the Cragar SS 15"X8 with a 235 tire will fit. The reason I wanted to go with the 8" wheels is, I thought it would fill the wheel-wells out a little more fuller, and I thought the 8" Cragars would have a little more deeper dish look compared to the 7"(although I have not been able to compare 7" and 8" side by side to know for sure).
My question is: How will going from a current 7" tire, to an 8" tire affect my ride/steering/handling? Will I notice the increased road friction in any negative way?
Thanks for any comments and advice!
Moderator, Electrical Bay
Hi Hank. The 6.00x16 tires that came on your truck had a tread width of around 4.5" or so, a section width of about 6.5" and a diameter a bit over 28 inches. Any tire wider than this will make a difference in steering and handling, but if you've been ok with what you have now, it may be that an extra inch won't be too bad. I think going from 215 to 235 will increase the width by around an inch or a bit less...if memory is right about 3/4 of an inch is what I'm thinking.
~ Jon
Riding in the Passing Lane
The best combination for handling is the tread width of the tire is the same as the width of the wheel. I like 235X15 tires on 7 in wheels. They drive good & look sharp.
George
1972 Chevy c10 Cheyenne Super
I'm willing to wager my pink slip that no one in existence can tell the difference between a 7-inch wheel and an 8-inch wheel just from riding in the truck.
The industry standard for wheel width VS tread width is 80%. A 235 MM tread width tire has a footprint of 9.25". 80% of that width is 7.40". An 8" wheel is only slightly too wide, so either one will be sufficient. Putting that much rubber on the road without power steering, compared to an original equipment skinny tire is going to give you an upper body workout, no matter which wheel width you choose.
Putting that much rubber on the road without power steering, compared to an original equipment skinny tire is going to give you an upper body workout.....
aka Armstrong Power Steering. grin
Insomniac
Insomniac
I think Jay Zed is correct. I have tires on 6" and 7" rims. Here's a picture. Can you tell which rim is the wider one?
(ignore the plank on top - that's just there to stop them from falling over - one tire is not noticeably taller than the other)
Gord 🇨🇦
1954 1/2 ton 235 4 speed
