1 members (Thomaslb), 138 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#1283110 10/09/2018 11:09 PM
What is the trick to oil/grease hood spring on a 49 -3100? How are the springs separated? Also what oil/grease is used? Thanks
dougs #1283113 10/09/2018 11:22 PM
I just use a white lithium spray myself, being careful not to get it on everything.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Will lubing them make them stop squeaking? Every AD hood I've owned has sounded like a haunted house door.
1951 Chevy Panel Truck
dougs #1283244 10/11/2018 12:45 AM
I find the sound musically calming myself, similar to the hollow thunk when you slam the door..
Never noticed a sound when I open the hood. Instead, I'm thinking about if the motor will start when I turn over the key.
Craig
2 Offline
it is a reassuring haunted squawk yes smile
i too have sprayed and oiled, and still... that sound.
maybe if one would strip all the parts, then nickel plate or anodize the spring and other bits, then reassemble with a final hot wax dip.
prob won't last, as soon as the plating wears through, the sound may come back.
-s
