8 members (Hotrod Lincoln, sudsyz, Chip O, Gdads51, 1955 1 Series, stlcardinalsguy, tclederman, 1 invisible),
67
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All, I am trying to find a picture of the seat adjustment spring location. the assembly manual is very difficult to see where one end of the spring connect. I see the hole in the back where the spring goes but not sure about the other end. I see a screw on the side of the track, does it go onto the screw? | | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Will lift my seat up today and see what I have going on. Stay tuned.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | On mine, there are two adjusting rails. Each rail has it's own spring with the small leg of the spring being attached to the lever plate that pivots into place, each time you move the seat. The longer end of the spring is fastened to the side of the rail, via a small hole on the side. So when you activate the seat adjusting lever, it activates the rail mechanism on the driver's side and via a long steel rod, activates the passenger's side rail mechanism. Wish posting pics on this site was more user friendly.
