2 members (Still At It, wilbur53), 130 guests, and 3 robots.
Topics128,196
Posts1,057,387
Members48,471
Hi All,
I am trying to find a picture of the seat adjustment spring location. the assembly manual is very difficult to see where one end of the spring connect. I see the hole in the back where the spring goes but not sure about the other end. I see a screw on the side of the track, does it go onto the screw?
Will lift my seat up today and see what I have going on. Stay tuned.
Craig
On mine, there are two adjusting rails. Each rail has it's own spring with the small leg of the spring being attached to the lever plate that pivots into place, each time you move the seat. The longer end of the spring is fastened to the side of the rail, via a small hole on the side. So when you activate the seat adjusting lever, it activates the rail mechanism on the driver's side and via a long steel rod, activates the passenger's side rail mechanism. Wish posting pics on this site was more user friendly.
Craig
Moderated by  ndkid275, Phak1
