5 members (Gdads51, papas52, Bruce 1954-4100, tclederman, Forty9), 102 guests, and 0 robots.
Topics128,110
Posts1,056,257
Members48,437
#128278 09/24/2007 6:32 AM
Hey all this is a question for you guys that either own or know about the 1937 1/2ton GMC pick-ups type (T-14B). i have not been able to locate much information or pictures of the orginal running boards for these trucks. the boards on my truck were home made jobs from the P.O. and not a very good job at that i did find a small pieace of the old board (i think it is )under part of the 1/4 diamound plate used by the P.O. The pieace i found looked to be ribbed? is that what the orginals were like ? ribbed? somewere i read that they were of a diamound pattern. and i found a very nicely restored 2-1/2 ton flatbed at a show in indiania that had this diamound pattern on the running boards.ANY INFO WILL BE HELPFUL THANKS Earl
#128279 09/24/2007 3:12 PM
Ex Hall Monitor
Ex Hall Monitor
All I've seen are ribbed. You might check out the gallery & see what you can find. Another option is Google images.
#128280 10/01/2007 8:24 AM
Tiny thanks ia have found pictures of the board recently and you are right they all have ribs now to find a set of gently used orginals if i can .thanks again Earl
