| | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 70 | Hey all this is a question for you guys that either own or know about the 1937 1/2ton GMC pick-ups type (T-14B). i have not been able to locate much information or pictures of the orginal running boards for these trucks. the boards on my truck were home made jobs from the P.O. and not a very good job at that i did find a small pieace of the old board (i think it is )under part of the 1/4 diamound plate used by the P.O. The pieace i found looked to be ribbed? is that what the orginals were like ? ribbed? somewere i read that they were of a diamound pattern. and i found a very nicely restored 2-1/2 ton flatbed at a show in indiania that had this diamound pattern on the running boards.ANY INFO WILL BE HELPFUL THANKS Earl | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | All I've seen are ribbed. You might check out the gallery & see what you can find. Another option is Google images.
| | | | | Joined: Jul 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 70 | Tiny thanks ia have found pictures of the board recently and you are right they all have ribs now to find a set of gently used orginals if i can .thanks again Earl | | |
