| | | Forums66 Topics128,163 Posts1,056,920 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 40 | A friend purchased a 49 3/4 ton. It had an 8v battery in it and it was removed without identifying the terminals. A new 6v was installed neg gnd. The truck failed to start and the cable (12v type) from the battery to stomp switch melted. A new 6v type cable was put on and the starter smoked. I was not there to witness this, just trying to help. The P. O. claimed it was a Pos gnd system, whitch seems odd to me. I looked at the way the ignition is set up and its the same as my 54s (neg gnd) The old 8V is gone, but I looked a a pic of it prior to removal. With the terminals toward you the starter cable was on the right. Other 8v batteries I looked at have the Pos terminal on the right . Maybe to be run in a series for golf carts ect. Most other batteries have the Pos terminal on the Left when closest to you. What can I do to determine if it in fact is a pos gnd or a neg gnd set up?
| | | | | Joined: Feb 2004 Posts: 29,853 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,853 | The ground polarity doesn't matter. If cables and/or a starter smokes, there's a dead short somewhere. Start from scratch with a new starter (rebuilt, actually). New ones haven't been available for over 40 years. GMC trucks run positive ground- - - - -Chevy is negative. 8 volt batteries were used in tractors- - - -never on street vehicles. By the time the charging system gets modified to accommodate an 8 volt, you could have bought 2 or 3 correct 6 volt batteries with the same money. Jerry
