3 members (dt235sd, Bucker, UtahYork), 160 guests, and 4 robots.
Topics128,196
Posts1,057,390
Members48,471
I made this video two weeks after buying my first Chevy truck. Turns out this truck has more than a few issues but haven’t we all. Any help and advice is alway welcome. I’m not much for blogging but I do enjoy making the odd video so I will be filming my work including the mistakes. I normally make videos about electronics equipment, but I really just film what’s on the bench.
Thanks and regards Chris - Sheffield UK
www.youtube.com/watch?v=lnX-DZyMM6s
In today's video I doing some more painting and treating the centre cross members with rust killer.
www.youtube.com/watch?v=NkXLWzy4_4M
Today I’m replacing the Axle oil seal on the Chevy 3600 truck. Part 1 of the video is removal and cleaning the hub.
www.youtube.com/watch?v=64Q17cBYK_k
Part 2 of the axle oil seal replacement. In this video I am adjusting the bearing preload. I found this job quite taxing, did I get it right. Please let me know.
Thanks Regards Chris
www.youtube.com/watch?v=xGwfDxlAklg
This week you can see the rear cross member this was previously blasted by the previous own and left in poor condition with almost no paint. I have painted the rear cross member with a two part epoxy. I am really happy with how this has turned out. In this episode I make a better job of correctly installing the wiring to the rear lights.
www.youtube.com/watch?v=R0mPf7N3eJE
Please like or subcribe and leave comments as its all good. I am trying to get to a 1000 subs so I can do some live streaming projects in the future.
Thanks regards Chris
Fox Offline
Chris,
This is a great idea. Keep blogging and the videos coming! Nice truck by the way.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Things to do on the Chevy 3600
Regards Chris
www.youtube.com/watch?v=ivs2IJ6nwkE
Today I am changing the gear oil in the differential using a yellow metal friendly EP80-90 gear oil. Perhaps this video should be considered as a how Not to do it.
Thanks for the nice comments.
If you interrested in following my progress please subscribe I dont make money from the channel but is alway nice to gain a few more subcribers and comments
Regards Chris
www.youtube.com/watch?v=VLYNtnQma54
Crusing in the Passing Lane
Don't know of any yellow metal in a diff?
Ed
I was told they contain brass or Bronze - Think it was on this forum, but never had one in bits etc.
Chris
I've had the differential apart on a '54 Chevy Station Wagon, and unless there's bronze in the roller cages, there isn't any yellow metal in them. It was a long time ago, though.
The first run out. Things could have gone a lot better LOL. I think it’s a fuelling problem but need to investigate this further. Could be the tank is full of rust blocking fuel lines.
www.youtube.com/watch?v=uPJvTjDKDIM
Well Hello again everyone. I’m going a bit of piste today with two videos showing the recommissioning of an old Lucas Ahooga horn and installing it in the Chevy. It may not be original equipment but it’s still fun.
Thanks for watching Regards Chris
www.youtube.com/watch?v=vKBww9DCo7k
www.youtube.com/watch?v=1HD821nvFPQ
Well hello again everyone. I’m replacing the water pump and radiator on th truck. This is part one of the work removing the pump and radiator and testing the thermostat.
Regards Chris
www.youtube.com/watch?v=un6UB4MwssA
This is part 2 of the pump and radiator replacement video
Thanks for watching
www.youtube.com/watch?v=3C5heo_YK7M
This time I’m going off topic slightly to investigate a fault with the Petronix ignition system. This video is about looking at the spark gap and how it effects the primary currents. Later I will be updating the system to the Petronix 2.
Watch part one here:
www.youtube.com/watch?v=Y-Hwx5RJPLc
Final part looking at the 235 / 216 ignition. Just skip to the last 30 seconds to see me making an arse of myself
www.youtube.com/watch?v=CO2Cz9Ti2U0
Installing the Petronix II in the Chevy 3600 Truck.
I cannot say i am very impressed so far. I had to cut the rotor arm down as it was hitting the top of the igniter. Not sure yet if the new igniter has fixed the problem with the overheating coil. I have installed a new coil as the Petronix soil was shorted out internally.
Thumbs down to Petronix II
www.youtube.com/watch?v=DvLZdTNQk2I
Please leave your comment and let mw know what you think or if you are running the petronix unit.
Chris
OK went out for my first drive today where the truck ran quite well and didnt breakdown. I am taking that as a win! nanner
Well done Chris. One victory at a time. I have had pertronix before and had one failure a couple hundred miles from home with a car full of family on a Sunday about 25 years ago. From that day on, I always carry a spare set of points and condensor as well as some small distributor screws in the glove box with a match book, regardless of whether is it pertronix or standard points that you are using. The match book can either be used for gapping the points or setting light to the vehicle depending of what kind of mood you might be in.
Truck looks great.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Good job, Chris,
I have a 6v Pertronix unit in one 54 truck, a 12v conversion Pertronix unit in another 54 truck, and original style points/condenser set-up in another 54 truck. I carry/carried a set-up/adjusted/tested spare points/condenser distributor as "insurance/assurance" when I traveled in any of the trucks. I also carry a vacuum gauge, for quick-and-dirty/easy timing and distributor setting/adjustment.
Your truck looks real nice.
Thanks Steve Tim
I have put the old Petronix unit in the glove box as it was working. Hopefully I wont have two fail on the single journey. Unfortinately the previous owner has damaged the holes in top plate of the distributor so I cannot easily put points back in. I do have a spare distributor from a 235 engine but just checking the drive gear material cast iron or steel.
Also bought a 235 engine to rebuild and have another 235 engine coming in september for spares if the price is right.
I think the next job will be to sort out the over fueling problem with the Carb
Thanks for all the support from the Stovebolt Forum
Regards Chris
Moderated by  Phak1
