| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2017 Posts: 2 Moderated | | Moderated Joined: Jul 2017 Posts: 2 | Anybody have any advice on getting the ignition switch out without having the key? I have a new one I would like to install but haven't figured out how to remove the original. (1952 2-ton) Chevrolet.
Thank you | | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | You might try pulling the lock from the door and see if there is a code stamped on it. If there is, you can take it to a locksmith and have him code cut a key. If you are lucky, the door locks and ignition are original to the truck and are the same. If you don't have a lock smith that can code cut the key, you can send the code to Jesser's Classic Keys. http://jessersclassickeys.com/
Mike
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Remove the complete ignition switch from the dash?
First disconnect the battery. Then remove wires from the 3 terminals on back of switch. Finally loosen (don't need to remove) the two screws holding switch to dash from back side, turn a little one way or the other and remove the switch. These screws are usually clutch head.
No key needed except possibly some early models, perhaps 1947, with a little tail hanging down on the front of the ignition switch cylinder, allows using switch without key. This tail can make it difficult to remove the entire switch depending on which position it is in, or may need removing cylinder with key then switch.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | The bezel nut that holds the switch into the dash won't come off without destroying the chrome disc that covers the lock tumbler. It's easy to remove the tumbler- - - - -IF- - - - -you have a key that fits. Otherwise, you're going to need to pick the lock so you can turn it away from the "off" position and expose the release pin that is accessible through the small hole in the chrome disc where the key is inserted. Once that lock pin is depressed, you can turn the lock tumbler further to disengage the tumbler from the switch. THEN the bezel nut can be removed. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Not the best picture, but should show that the 48-53 ignition switches don't have a bezel. The whole switch just slides in from the back of the dash and held with two screws. https://photos.app.goo.gl/g3EnHEqh3TaXxVK77The stainless/shiny part is the end of the lock cylinder only | | |
