1 members (KEVINSKI),
119
Mod | | | Forums66 Topics128,162 Posts1,056,943 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 94 | hello , I have a 1939 Chevy 2.5 ton truck , I would like to know if a added key lock would fit separate from the door handle on the passenger side ? also I have the batwing front engine hood, is there a locking mechanisms for this type of truck ? aftermarket is fine , I would just like some security when traveling. thank you . | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | Pete, for the doors, you could look into something like these, Speedway Universal Suicide Door Safety Latches, go to Speedway Motors, there are other brands also or you could even make your own. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | My fathers 39 had keyed door handles on both sides, mine only had a key lock on the driver side. I just reached over flipped the door handle to lock that side.
