1 members (Ponchogl),
108
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 226 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 226 | Happened across what appears to be a ton-and-a-half truck. Got the number off the door jamb plate.
P53S 026901
1-1/2 ton truck, 4400 series 1953 St. Louis Plant 25,900 one made that year (?)
This look correct? What came off the tag, I know is correct, it's my interpretation of that code I question.
Looks like a bunch of this size truck made that year?
Mike
1951 3100 5 window
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hello, MIke,
P53S 026901 - you almost got it right
P 53 S 02691
P = 1.5 ton 4400 53 = 1953 S = St Louis, MO assembly plant 026901 = 26901-1000 = 25901th truck (all sizes) out of that plant in 1953
In 1953, the serial number sequence was for all trucks assembled.
| | | | | Joined: Mar 2016 Posts: 226 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 226 | Makes sense, quantity is for ALL trucks made out of that plant. I kinda figured that it couldn't be that many of this series truck made there that year.
My 51 3100 has 4484 on it's plate, made in December of 51 in St. Louis.
Mike
1951 3100 5 window
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
