4 members (Otto Skorzeny, SNOYL, Wayne67vert, Barry Martak), 101 guests, and 3 robots.
Topics128,096
Posts1,056,482
Members48,444
#1282410 10/03/2018 7:26 PM
Folks — New here and thinking of joining the Big Bolt world. Have a chance to purchase a 1954 4100 dump truck in really good shape, but a little worried about availability of driveline parts and brake parts.
Can shoes, drums, cylinders, bearings, seals and such be found?
Also — are cab parts the same across 3100/4100 series? This truck has a shattered passenger window.
I am used to working on old things, and also used to chasing down hard to find parts. Got a little worried when internet searches turned up nil on the brake parts.
If I new I could keep her on the road I would buy her in a heartbeat — just a beautiful truck that needs TLC. Looking for advice as to whether or not to make the plunge. I have restored cars going back to 1931, and have a brother in law as a resource that repairs tractor trailers and heavy construction equipment.
Scott
Welcome,
Brake drums are pretty much only available used.
Cabs and all their parts are same as small trucks. Fenders, hood, and grill are big truck items.
All the rest is easy.
Go for it.
•1952 Chevrolet 3800 pickup
---All pictures---
Big Bolt Forum Moderator
I am with Grigg, go for it!
Mike
x3.
Everybody's got pickups!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Former Workshop Owner
Hello Scott,
Shoes can be re-lined. Wheel cylinders can be rebuilt (parts are available) if they're not too pitted. Lots of parts can still be found if you really look. The biggest problem I have with big bolts is the cost of tires.
If you have the space, and live in an area where you can drive it, I too say go for it.
Welcome to the Stovebolt.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Thanks for the feedback - leaning towards buying her. Attached (hopefully) are some pics - no, I am not a flame guy.....
Appreciate any feedback on things you see in the pics, particularly about the wheels - I am no expert, but did not think these are Widowmakers... hope I am not wrong.[img]http://i1091.photobucket.com/albums/i397/stouchton/20181001_163038.jpg[/img]
http://i1091.photobucket.com/albums/i397/stouchton/20181001_164518.jpg
http://i1091.photobucket.com/albums/i397/stouchton/20181001_164532.jpg
http://i1091.photobucket.com/albums/i397/stouchton/20181001_164546.jpg
Does $5K seem reasonable for being drivable?
Scott
the price all depends on condition. I paid 500 for my 55.2 6400 and 900 for my 58. The 58, I drove onto the trailer when I picked it up, the 55, I drove off once I got it home and cleaned out the carb.Both trucks need all 6 tires and neither one had brakes that worked.
Tires are a big expense, if all 6 tires are good, that is worth some money, interior, mine were full of mouse stuff, and seats completely shot. If yours has been re-done inside and fairly clean, or even repainted, that is worth some more $$.
Mike
The wheels shown are the safe/serviceable kind of multi piece wheels.
Bumper is on upside down... perhaps that helps in your negotiating smile
Price is your call, is it worth it to you? My guess is it's in the right neighborhood, without having seen the truck in person to better judge condition.
Sometimes just because it looks nice and has paint on it doesn't mean it's worth more than an old original with faded and missing paint.. the "pretty" one might be full or rust and poor workmanship. Always cheaper and or better in the long run to buy the truck without rust, or with as little rust as you can afford up front. Replacing/fixing rust properly gets expensive, or corners are cut and it reappears.
---All pictures---
Thanks guys .
I am having trouble putting a value on it, and looking on the internet just confuses me - found a couple non-runners for more money..... so your input really helps.
Here are some more details:
Interior is redone, new headliner, reupholstered seat, new door panels, dash repainted
All brake lines replaced
Front wheel cylinders replaced with 1"in place of 7/8".... don't know what to make of this...
Master cylinder replaced
Clutch, pressure plate and throwout bearing replaced
New radiator
235 babbitted engine replaced with 235 with insert bearings
Electric Wipers
Front brake drums replaced
Brake power assist rebuilt
New speedometer
Was inspected and on the road last year.
[img]http://i1091.photobucket.com/albums/i397/stouchton/4100.jpg[/img]
Crusing in the Passing Lane
The wheel cyl. replacement will make the brakes more powerful, at the expense of less volume, which might not matter.
Ed
One last question before I make my decision - how much should I be worried about the differential?
This truck runs fine, and sounds fine - so I am not suspicious of anything. But it is old, and things go wrong. Is the differential serviceable, can parts be found? I have been doing a lot of research, and found a lot of good information on this site. But if I would need ring or pinion gears at some point, or bearings or seals - is there a source? Or do I need to scrounge used parts? Does someone here know where parts can be found?
Is it easy to transplant something out of a more modern vehicle?
I want to give this truck a new home, and take care of it. Also want to enjoy it and run it. It would have an easy life - but I sort of need to know if I can take care of it (if that makes sense...).
Thanks for your help - this is not an easy decision.
Rear axles rarely give trouble if they have oil in them and not water.
Bearings and seals are generally available and easy to find.
Entire rear axles for these trucks are essentially free, if you need one and ask around they turn up, and aren't desirable for any other application.
More modern choices also exist, but to keep your same bolt pattern the newer versions have rear disc brakes, which then would require adapting front disc brakes to complement them, also possible.
Otherwise many other newer axles can be made to fit, some better than most, but wouldn't have same bolt pattern.
If you like these trucks there's no reason not to have one, they are all quite serviceable and easy enough to get about anything you could ever need. Also quite adaptable if you want more modern stuff and not all original, while maintaining original appearance.
---All pictures---
Grigg - thanks for your help and feedback. Looks like this one will be following me home this week.
As Grigg said, bearings and seals are not hard to find as GM didn't reinvent the wheel for just that truck but used off the shelf parts from ones like Timken, Bower, or LMC. We have a 1928 Chevy dump truck that had no brakes at all on the front, just the backing plates Know a man with a 28 stake bed that let us copy the brake shoe steel backing ( they are NOT hard to make) and most important the cam/lever/pivot/rod of the mechanical brake set up. Summary is these old trucks are so simple that if you can't buy it you can make it.
[img]https://i.postimg.cc/QBh8R87S/IMG_4582.jpg[/img]
Evan
Thanks coilover! I have committed to taking the plunge.
You have a nice truck there.
