1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
#128237 09/20/2007 7:20 PM
Are the body panels on a 1 ton the same size as the 1/2 ton models? I was curious because I see a lot of comments about 3/4 and 1/2 but never anything about the 1 ton.
Also if they are does anyone know if a 54 GMC door is the same as a 52 Chevy door?
#128238 09/20/2007 7:33 PM
Junior Member
Junior Member
Hey,
I allways read that the cabs of the trucks made in the 50's were all the same, they just had different sized front fenders to cover the front wheels. I've read this in several of the different forums.
With the best of regards,
Strat
My 1957 Chevy 3100
#128239 09/20/2007 7:48 PM
Cabs are same, front parts and rear parts, side parts. That is.. *as far as I know.*
Now, "body Panels" I am assuming you have a truck, and well, not a panel 1T. I dont know if your asking about thickness, length or width. But a 1/2T OR 3/4 ton WILL NOT fit the bed length of a 1T. All tailgates will fit. And pockets will work. But not in length.
Chey
LOST1953
My favorite color is CHROME
The ugliest trucks are driven by the prettiest girls wink
I dont suffer from insanity, I enjoy it!
O Lord, WHY did I buy another "Thing"? (again??)
1953 Chevy 3800 1-ton Gallery
More photos at MSN
#128240 09/20/2007 8:07 PM
Sorry front fenders and hood size is what I was talking about. I hear they were the same I just wanted to make sure before I purchased the truck.
#128242 09/20/2007 9:37 PM
I am getting a 1 ton that I would like to drop down a bit, but I cannot get anyone to tell me if you can swap out the spindles in the front easily and put a standard 5 lug on there. The rear I know can be swapped out easily.
I have an issue with the size of the dually might cause me some issue getting in the back yard. I was wondering if I can run a dual as a single and how far the center piece would extend past the first wheel, I do not think it adds that much to the truck but I do not know. Also what would be the best doner for a single rear with a higher gear.
#128243 09/21/2007 12:01 AM
Jackyl,
I suggest you re-post that over in General Truck talk, but if you want to swap to 1/2 ton spindles you have to swap to 1/2 ton axles. The king pins don't match.
Paint & Body Shop moderator
