4 members (texas46, eclector, Otto Skorzeny, KEVINSKI), 190 guests, and 0 robots.
Topics128,100
Posts1,056,178
Members48,436
After 7 years my B is done and I would like to buy a Carter as I'm not interested in rebuilding this one. I want a proper rebuilt one addressing not just the soft rebuild kit materials but also "hard" parts like throttle plate etc that have been likely beat in the last 60 some years. Any suggestions on who to give my money to? Not sure model number to chase or where look for a supplier why I ask. Won't have a core so will need buy outright. 1959 235 in my apache. Thanks in advance for any insight offered.
Sir Searchalot
Sir Searchalot
Contact member carbking. Go to top of this page. Click user list, click "C". Find carbking, click it and see his website url and email. He will supply the carb you need.
Carbking (Jon) prefers phone calls Mon-Tue 9am to 4pm central. 573-392-7378
Thanks to you both! I'l touch base with him tomorrow.
Only accepts calls on Mon and Tue
Moderator, Electrical Bay
J Online: Content
The 3211s is a very nice carb for the 1959 model. It sort of depends on what air cleaner you have, however.
~ Jon
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Carburetion specialist
The chart in the link below will help you determine what CARTER recommended for your application:
http://www.thecarburetorshop.com/Carter_YF_Chevrolet.htm
Back in the day, Carter, Stromberg, and Zenith all produced replacement carbs for the Chevrolet.
Additionally, many other carbs have been adapted, with varying degrees of success.
And today, there are some offshore clones available. And while I have not personally inspected the offshore clones for the Chevrolet, I have had a number of customers try the offshore clones for the Willys Jeep and the Ford 8N tractor, often sending them to me for rebuilding after about 25 hours of use. They were not rebuildable. These two "carbs" are extremely useful if one has a strong right arm (or left arm, no discrimination here) AND a rabbit problem in one's garden!
All products have advantages and disadvantages. The clones we inspected had two "advantages": (1) initial cost was ridiculously low, and (2) they were new and shiny. We do suggest if buying them to use, buy them by the dozen! wink
Jon.
The Carburetor Shop
Jon, many thanks for weighing in on the clones. I have seen them on ebay and often wondered whether they were a viable replacement. My arm is not that strong so I think I will pass, lol.
Mike
Mike - the downdraft fake Carter W-0 carbs for the Willys Jeep are of such poor quality, that, if one removes the fake from the engine after 500 miles (assuming it lasts 500 miles wink ) and tries to set the fake on one's workbench, it will roll off. The zinc alloy (pot metal) is so poor that the flange will have warped maybe 50 thousandths. It is no longer flat. And people gripe about idle quality if the throttle shaft wears 3 thousandths.
But depending on the greed of the seller, it only costs from $89.95 to $139.95. grin
Jon.
The Carburetor Shop
Insomniac
Insomniac
Putting a new carb kit in after 7 years doesn't seem too bad to me. How many times can a carb be rebuilt before it's toast?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks for all the info folks! I'll be sure to call carb king next week on Monday or Tuesday as mentioned and go from there.
Auto-correct?
Josh - I am sold out of Carter YF carbs for the 235. If you wish to call, will still be happy to discuss your carb needs, even if I don't have one.
Jon.
The Carburetor Shop
I bought 2 yf carters for a willys jeep. They ran good but the throttle worked backwards than the rochester. My linkage pushed up and these pull down. these were for a hurricane engine.
