1 members (dt235sd),
307
7
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | For you guys that have been working on the 64-66 trucks have any good photos you can share with me that shows the inside of the doors on a 64-66 so I can see where I need to break the interior and the exterior paint? I am painting the outside of my truck red and the inside Fawn, and I am not real sure where to stop and start on the inside of the doors.
I hope you know what I mean..
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I've got a reference book (I can't remember the name) that says the exterior paint stops at the edge of the outer door skin. When I painted mine, I painted the outside color first and then masked to the edge of the skin where it wraps around the edge before painting the inside. I hope this helps.
Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Thanks Jeff,
So really, the outside door skin is the only part that is the exterior color. The rest of the door should be the same color as the inside of the cab. Right?
| | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | It is on my 63, if that helps. 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Thanks Pete. Last week I took a few days off and got the inside of the cab and doors painted. I just painted the doors the same color as the inside of the cab except the outside door skin. I just assumed that was right. I am happy with it too so I guess I can't be wrong. Thanks for the response for sure. "Nothing can be finer than living in the Carolinas." Although for SC, a smarter governor would be nice....
