0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | After 7 years my B is done and I would like to buy a Carter as I'm not interested in rebuilding this one. I want a proper rebuilt one addressing not just the soft rebuild kit materials but also "hard" parts like throttle plate etc that have been likely beat in the last 60 some years. Any suggestions on who to give my money to? Not sure model number to chase or where look for a supplier why I ask. Won't have a core so will need buy outright. 1959 235 in my apache. Thanks in advance for any insight offered. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Contact member carbking. Go to top of this page. Click user list, click "C". Find carbking, click it and see his website url and email. He will supply the carb you need.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Carbking (Jon) prefers phone calls Mon-Tue 9am to 4pm central. 573-392-7378
| | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Thanks to you both! I'l touch base with him tomorrow. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Only accepts calls on Mon and Tue
| | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | The 3211s is a very nice carb for the 1959 model. It sort of depends on what air cleaner you have, however.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The chart in the link below will help you determine what CARTER recommended for your application: http://www.thecarburetorshop.com/Carter_YF_Chevrolet.htmBack in the day, Carter, Stromberg, and Zenith all produced replacement carbs for the Chevrolet. Additionally, many other carbs have been adapted, with varying degrees of success. And today, there are some offshore clones available. And while I have not personally inspected the offshore clones for the Chevrolet, I have had a number of customers try the offshore clones for the Willys Jeep and the Ford 8N tractor, often sending them to me for rebuilding after about 25 hours of use. They were not rebuildable. These two "carbs" are extremely useful if one has a strong right arm (or left arm, no discrimination here) AND a rabbit problem in one's garden! All products have advantages and disadvantages. The clones we inspected had two "advantages": (1) initial cost was ridiculously low, and (2) they were new and shiny. We do suggest if buying them to use, buy them by the dozen!  Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Jon, many thanks for weighing in on the clones. I have seen them on ebay and often wondered whether they were a viable replacement. My arm is not that strong so I think I will pass, lol.
Mike
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Mike - the downdraft fake Carter W-0 carbs for the Willys Jeep are of such poor quality, that, if one removes the fake from the engine after 500 miles (assuming it lasts 500 miles  ) and tries to set the fake on one's workbench, it will roll off. The zinc alloy (pot metal) is so poor that the flange will have warped maybe 50 thousandths. It is no longer flat. And people gripe about idle quality if the throttle shaft wears 3 thousandths. But depending on the greed of the seller, it only costs from $89.95 to $139.95.  Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | Putting a new carb kit in after 7 years doesn't seem too bad to me. How many times can a carb be rebuilt before it's toast?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Thanks for all the info folks! I'll be sure to call carb king next week on Monday or Tuesday as mentioned and go from there.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Josh - I am sold out of Carter YF carbs for the 235. If you wish to call, will still be happy to discuss your carb needs, even if I don't have one.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I bought 2 yf carters for a willys jeep. They ran good but the throttle worked backwards than the rochester. My linkage pushed up and these pull down. these were for a hurricane engine. | | |
