| | | Forums66 Topics128,193 Posts1,057,241 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 71 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 71 | Well hope your all doing well , My little diesel S-10 Chevy pickup munched a injection pump so my 48 ex-fire truck 2 ton has become my Daily driver . With the 4.11 ratio Dana 70 HD ford motor home rear axel ,running 265 / 75 / R16 tires it has a Clark 5 speed non syncro which was stock for a lot of fire trucks ,5th is 1 to 1 . With this combo it cruises at 55 no problem . I just went to single rear tires and gas mileage is a whole lot better . still 20's on the front but I just found some 7.50 16's which is the same Od as the 20's and I think the 16" wheels clear the break drums . I just put a 70's 250 6 cyl Mono-Jet Carb on the 216 it sure runs good with this carb .I found a hidden by a aluminum plug adjustable needle jet under the float bowl that really helped get this crab dialed in on the 216 . The only down side is no power steering and down shifting the non syncro tranny ,Florida traffic is a pain in the butt . Picking up a 1971 GMC tilt cab also ex-fire truck 21,000 miles cab & chassis to build a 8' x 16' removable tiny house on . Well got to run may you all have a peaceful time in the upcoming holiday seasons . Paul N.
1948 Chevy 2 ton flatbed ex fire truck , and various motorcycles .
