1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1281608 09/26/2018 10:42 PM
This may be a stupid question but I am changing my kickdown cable on my turbo 350 and when I took the old one out of the transmission about a quart of transmission ran out. Is this normal. Thanks for the help.
hebert2756 #1281660 09/27/2018 3:06 PM
The cable connector mounts fairly low on the case so it is likely some fluid will run out. Also, the converter will loose some fluid into the case if the vehicle sits for a while.
Fred
hebert2756 #1281663 09/27/2018 3:55 PM
Yes, that's pretty normal, especially if some fluid has drained out of the converter.
