| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2016 Posts: 47 | This may be a stupid question but I am changing my kickdown cable on my turbo 350 and when I took the old one out of the transmission about a quart of transmission ran out. Is this normal. Thanks for the help. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The cable connector mounts fairly low on the case so it is likely some fluid will run out. Also, the converter will loose some fluid into the case if the vehicle sits for a while. Fred
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Yes, that's pretty normal, especially if some fluid has drained out of the converter. Jerry
