1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 23 Junior Member | | Junior Member Joined: Aug 2007 Posts: 23 | The wife and I are out shopping today. Me, I always have a secret agenda when I take "her" shopping. Today it was an airbrush to finish up some controls inside my cab and to be able to do some easy touchup work without breaking out the big boy and having to clean it up. We stopped at Hobby Lobby to look at paint stuff ERR... I mean wreaths for the fall decorations. The good airbrush kit was 149.00 and the cheapy was 80 buckaroos. Sadly I paid for the @#$%^&* stuff she picked out and sulked. Next up I had to go to Big Lots. I always look through thier knock off tool stuff. I buy zip ties, brushes, tape, and other junk there. WAIT WAIT. . . Whats this. . . AN AIRBRUSH!!!!!!!!! at Big Lots. Get this, it was 8 dollars. main components were steel and brass. It came with 2 glass pots, a 4 foot line, and an adapter to hook up to shop air. I am going to use it tommorow and if it will atomize the paint and lay it down for me, I will be impressed. I will give a full report on this "EL Cheapo" tommorow night. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | curious to find out the results.........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Aug 2007 Posts: 23 Junior Member | | Junior Member Joined: Aug 2007 Posts: 23 | Never got to shooting today. Soory, will fill you in tommorow hopefully. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Ya know, Hobby Lobby has a discount coupon on there website, just used one for 40%off last weekend, check it out!!!
Mike | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I have a Badger 2 stage gravity feed the wife bought me for x-mas a few yrs back ...Love it ! | | | | | Joined: Aug 2007 Posts: 23 Junior Member | | Junior Member Joined: Aug 2007 Posts: 23 | Overall I would say it was a good 8 buck investment. I touched up some bolts with it. At 4 inches it sprayed about a dime size pattern that was tight with little overspray (30 psi). I did find that I needed to thin down more than I do for my HVLP because of some slight spitting. I had a battery box that needed painting so I tried that to see how it did on larger surfaces. I could get about a quarter size at 6 inches and 45 psi. That was about as good as it got. and at that point and pressure it was hard to control overspray while overlapping.
As far as bolts, nuts, and knobs go, it does great and gives a good finish. I would recommend it for that. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I use those Hobby Lobby coupons on a regular basis, last 2 I used to get a Paasche Model V airbrush, awesome unit BTW, and a Revell Big T model kit.
Bill Burmeister | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | SuperDuke, Just about the best single action airbrush you can buy (only $20.00) is badger. I've painted 99.99% of all my work with a 15 year old model, it had never given me any problem. I just replace the older one with exactly the same model. I find I can turn it down to a find point and use just about 30 psi to do my work, although I do tend to thin down my paint. Here is a link to see the type of work I can do with one. http://good-times.webshots.com/photo/1414875678054402330rOugLp http://home-and-garden.webshots.com/photo/2421938260054402330GnWtcs This was using painted by using a special alumimum paint. http://good-times.webshots.com/photo/1414921840054402330QtLpCO LongBox, Are you a modeler? Have any pictures of your work? I just landed a job doing a model of a 1960 Chevy truck by Monogram, it will be Painted like the customers truck. Just drilled out the headlight for 12 volt ICL and am working on the tail light now. The V-8 with have all the usually plumbing. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Modelman , I do modelin durin the long PA winter ....pretty much all 1/48 scale WWI & WWII aircraft. Tim | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Longbox,
Did you scratch build the camper shell for the chevy? If so that looks great. The engine treatment for the '47 engine area is great too.
Jake | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The camper is a Model King re-issue of an old MPC kit, not being produced now since AMT went out of business.
