5 members (LAJones48, dt235sd, Samantha, mick53, 1 invisible), 177 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
#1279306 09/06/2018 12:56 PM
Hi All,
Starting to think of my last two driving months of this year and maintaining our 1952 Chevy 1/2 ton. My question concerns the necessity of changing antifreeze. I live in Michigan, drive 500 to 1000 miles each summer and use the traditional "green" antifreeze. The antifreeze still looks fresh with no floating particles or staining and checks out good for freeze protection. It has been in our truck for 7 years and from what I'm hearing I am past due for a change. Your opinions would be appreciated. Thank you.
Chuck52 #1279309 09/06/2018 1:02 PM
Given your miles driven, and the appearance of the coolant, and it checks out for protection, I would not change it.
Chuck52 #1279338 09/06/2018 5:00 PM
Thank you, Tim.
My thoughts also. Appreciate you taking the time to share your opinion.
Chuck
Chuck52 #1279340 09/06/2018 5:08 PM
To replenish the rust inhibitors and other additives that might have gotten a little tired, how about draining a gallon or so and replacing it with a 50:50 mix of antifreeze and water? A 50% mix protects to -37 degrees F., so there's not much of a reason to use a stronger mix unless you're in Fairbanks Alaska or somewhere similar. A 70% concentration is the max, since pure antifreeze gets slushy at +19 degrees. It takes a little water in the mix to kick off the freeze protection.
Chuck52 #1279356 09/06/2018 7:13 PM
Oh, hadn't thought of that. Makes good sense. Thank you, Jerry.
Chuck
Chuck52 #1279530 09/08/2018 4:06 PM
At $12-14 per gal. of concentrate, I think it’s cheap insurance to drain, flush, and completely change with fresh antifreeze. Remember, it serves as a coolant also, and the heat breaks down the chemicals much more than the cold does. The rust/scale inhibition factor is another function of antifreeze, so as Jerry says, putting in fresh provides superior protection there as well. Antifreeze also acts as a lubricant for the water pump. I think you’ve gotten your money’s worth after 7 years!! Time for some fresh chemicals.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Chuck52 #1279777 09/11/2018 12:43 AM
Thanks you Tim, Chuck and Jerry,
Greatly appreciate the advice.
Chuck 52
Chuck52 #1280478 09/16/2018 10:11 PM
Coolant (antifreeze) contains more chemicals than just ethylene glycol and the corrosion inhibitors are consumed over time. The new universal coolants have better corrosion inhibitors now and are good for 5 years unlike the old green coolant that was only good for 2 years. Use distilled water and mix it 50/50 with the coolant.
I would also do a citric or oxalic acid flush to remove any rust and scale. See Cooling System.
Chuck52 #1280847 09/20/2018 1:25 AM
Thank you, Frasco.
Chuck 52
Chuck52 #1281537 09/26/2018 2:13 AM
It's a 70/30% ratio here in the scorching desert
If you're talking 30% antifreeze for economy, a stronger solution actually increases boiling temperature as well as reducing freeze temp. IIRC, a 60% glycol solution gives the lowest freeze point, As Jerry said, even stronger solutions start increasing freeze (or slush) point. Those poor souls in Fairbanks have to use freeze plug heaters overnight to be able to crank them over. I've heard stories of people driving away from their tire treads when they froze to the ground. I've experienced the square tire symptom, but never lost tires to the cold.
fraso #1306709 04/11/2019 11:22 AM
Be careful about type of antifreeze to use.
I saw a report that stressed to use only the old green stuff. It said the modern antifreeze attacks the solder on radiators causing leaks.
Napa & others carry antifreeze that are labeled for older cars (I think 95 & older).
Just a heads up......
Chuck52 #1306764 04/11/2019 11:19 PM
Where does a guy get citric acid to do the flush?
1937 GC
Chuck52 #1306779 04/12/2019 1:40 AM
7
7 Offline
Your local parts store will have several flush products, if the system looks pretty good a light duty cleaner, back-flush, drain, rinse, fill with 50/50.
Chuck52 #1306784 04/12/2019 2:20 AM
Rebuilt a 235 last fall, filled with water and did a test run. Drained and worked on resto all winter and will be ready to fill with antifreeze soon. Would like to put cleaner in and flush as you said. Thanks for the tip. Bill
1937 GC
Chuck52 #1307064 04/14/2019 4:37 PM
I just cleaned and replaced the coolant in my 2005 silverado with prestone green. I've "heard" many stories of how the Dexcool tears down the seals ect. Not sure if it's true or not, but I don't have any leaks, yet.
Another quality post.
Real Trucks Rattle
Chuck52 #1307074 04/14/2019 5:57 PM
I see all sorts of problems with cooling systems that use Dex-Cool, mostly corrosion-related. It was originally developed to be more compatible with aluminum than the green stuff, but apparently they didn't test it well enough for long-term use. Older systems, especially the ones with copper radiators, really need to run the plain old green antifreeze. All my vehicles get a 50/50 mix with water- - - - -if that's ever too weak for Tennessee, I'm heading further south in a hurry! Since the coldest recorded temp in our area was -17 degrees F. I think I'm pretty safe!
Chuck52 #1307145 04/15/2019 1:50 AM
Crusing in the Passing Lane
I always use distilled water when I uses 50-50 mix. Had some unusual corrosion problems.
Ed
That's what we use up here! So if that's too weak for Tennessee then we're all in trouble!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Chuck52 #1312568 05/31/2019 2:02 AM
As Spotbiltxo stated as i was thinking it. Antifreeze also lubricates the water pump. You got your time out of it. Change it and worry about it in 7 more years. JMO
