7 members (Gdads51, frogfarmer, tclederman, JoeDude, Bill Hanlon, dt235sd, Jaison),
58
0
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 18 New Guy | | New Guy Joined: Mar 2017 Posts: 18 | Hey folks,mabe an opinion here? My 58 Chevy Panel Truck dash is missing holes.There is no hole for the ignition switch ( currently using an 80's column with ign).Also NO pre prepped area for a heater control panel. I'm wondering if this a very early REPOP that had few options? Im repalcing with a nice aftermarket column,so gotta drill me a new hole. Also.....according to LMCTrucks.com the hole next to headlight switch is for choke.But the one to the furthest right is for "throttle." What the heck are they talking about??? | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | Pictures... we need pictures  | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | On the left of the column, you have choke and light switch. On right of column you have ignition switch. You have three holes over the radio area. From left to right they are wiper, lighter, throttle. (that thar would be your "far right throttle"). Economy heater is a knob on a delete plate. Deluxe is levers on a control station in the dash. As said, on something like this, we would like to see pictures for future reference. Even a 58-59 GMC Fleet Option had all the holes.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2017 Posts: 18 New Guy | | New Guy Joined: Mar 2017 Posts: 18 | Basically NO hole for the ignition...Also does the "throttle" knob (cable) do what I think it means? It adjusts something on oem eng throttles???? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I'm guessing "kustom Kid" was playing around (tilt/key column). A repop dash would have an Ignition hole.
Yes, it allows for hand throttle from inside for lots of reasons we would never use. PTO, 4X4, uphill from a stop...for jitter foot Harry, etc. I would not bother with a hand throttle. Put a fake knob, use it for something else, map light/charger/security start switch or fill with a delete plug.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2017 Posts: 18 New Guy | | New Guy Joined: Mar 2017 Posts: 18 | A wolf wistle for the girls! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 |
Evan
