10 members (Otto Skorzeny, Joe H, 3B, baldeagle, Johnny Rib, 68ironhead, 2-Ton, 1955 1 Series, JW51, Guitplayer),
112
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 15 'Bolter | | 'Bolter Joined: May 2012 Posts: 15 | What would you guys recommend.
To be put into a '48 2-ton. A used '61?, mileage unknown 261 (3 hours away) or a rebuilt '58 235 long block with a 848 head (an hour away)? Same price.
I would have to change out front motor mount plate and get water pump adapter on both. 261: would probably need a couple of other tweaks that I have been reading about. 235: I could transfer most of the parts from my cracked '48 235. Can I use the same distributor, carburetor, remote oil filter?
Anything else I not thinking about?
Thanks for any input offered. D.
| | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | May we assume you've read our 261 rebuilding tech tip? If not, it will give you more insight as to what to expect with an unknown/unrebuilt 261 (or any engine, for that matter). And that an engine was "recently rebuilt" doesn't mean much unless *you* were the one doing it (and know all the cut corners ...  ) Just sayin'
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2012 Posts: 15 'Bolter | | 'Bolter Joined: May 2012 Posts: 15 | Thanks John for the quick reply. Yes, I read that and many other threads and articles here and on other sites.
Either way I will have to tear them down,to a certain extent, to install the motor mount plate. I would do a thorough inspection then.
Still probably won't know the corners cut.
I was wondering what the big advantage to the 261 was. (without the 848 head) If it is a hp thing, from my research, it looks like the 1958 235 has 145 hp and the stock 261 has 150 hp. Both far more than the 1948 235 @ 93 hp
D.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The extra displacement is very important even for daily use, and the only practical way to get almost 11% more (in comparable bore sizes). It increases the effectiveness of any other mods. By comparison, a 292-rod based stroker is worth about 5% displacement for $$$.
w/r/t/ Can I use the same: distributor, yes remote oil filter, yes carburetor, you could, but selecting a stock 261 carb (as someone better versed in this matter than I am will tell you) will save much grief.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1948 235 distributor will have a steel gear on it, not a good match for the later cast cam engines, although the dist gear can be changed.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2012 Posts: 15 'Bolter | | 'Bolter Joined: May 2012 Posts: 15 | Thanks,Panic Thanks Dave,
So if I go with the '58 235 which I think I'm leaning toward, I hit up Dave for the water pump adapter, use my pump and fan, my balancer and pully, generator (12v), my fly wheel, starter and bell.
I will still have to do all of the above if I go with the used 261. (That is enough for me to do for now, I am not prepared to rebuild the 261, (or even the 235) at this time.
On the 235 long block use my manifolds, but with a better carb. and could I go with the A-Team HEI DISTRIBUTOR 65KCOIL Early Chevrolet Straight 6 41-62 194 216 235 BLUE?
D. | | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | The 235 is a great engine. The A-Team dist may work ok, but it may do other things. I have one which worked but developed a strange habit of wicking oil up the shaft and into the body until it poured out the bottom of the cap. This Chinese product is sold by many sellers and has been for a long time. I bought the one I have on eBay in the late 90s because it was very cheap. Tom Langdon's mini HEI works well and Tom is a good guy. You can also adapt the GM 250 HEI to the 235 and it is a decent dist.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Diamond D, I tried to send you a PM but unable. I'd be interested in the 261 if you're not going to use it. Dave | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | If it was me, I'd buy them both if I could and then decide later. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2018 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2018 Posts: 37 | I love the the old 235 back in the 60's I had a 235 Impala convertible rebuilt the engine for $112.00 then added a Fenton manifold and 3 single carbs. Dad all most had a heart attack! Could drag race the 283's with nooo problem! Yes I would buy both the 261 more torque if I remember right! Old but not dead! Pops the truth is out there
Pops the truth is out there!
| | | | | Joined: May 2012 Posts: 15 'Bolter | | 'Bolter Joined: May 2012 Posts: 15 | Thanks for the heads up, Jon.
DaveV, I'll keep that in mind.
D.
| | | | | Joined: May 2012 Posts: 15 'Bolter | | 'Bolter Joined: May 2012 Posts: 15 | Believe me, Wally, it's in the mix. Not really in the budget, but I've been kicking it around.  D. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If it was me, I'd buy them both if I could and then decide later. Ditto | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I had a Langdon's Hei for 10 years and was very happy with it. He is great to work with.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Doing a front timing plate swap IS NOT a simple procedure. You'll be halfway through a full engine rebuild, labor-wise, before the new plate gets installed. Jerry
