3 members (DoubleB, Chip O, JW51),
173
Mod | | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Am looking for contact information of the company that makes the after market cable retract reels for the lower clamshell on the advance design Suburbans. Your time and effort greatly appreciated. | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** No longer need the info. **Was able to find the information. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hello, marzach
To help other bolters in the future, what is the contact information and part number? If it is on-line, would you please post a link to the company website and/or part?
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** The contact information is as follows ** Pullman Mfg. Corp. ** Ph# 585-563-8068 ** The reel to order to replace the lower clamshell cable retract reel is Pullman Mfg. Corp.** Standard reel "Type A" It is a near perfect replacement in appearance & function. ** pullmanmfg.com
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks very much, marzach | | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | Hi, I posted this information a few years ago. Pullman Manufacturing, www.pulmanfmg.com, part number is A-105, I was quoted $31.25 Contact is Silvia Swetman Pullman Mfg. Corporation (585) 334-1350 x 302 [email protected]
Lisa
1952 Chevy Carryall in completely original condition Pulled out of a barn in Colorado high desert
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Yes I use those too And danchuck cables for nomad I think | | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | I just called Pullman and they no longer make the reel with the cable and the ball on the end. Apparently there was a problem with the manufacturing process and according to Bill, they discontinued the part. Anybody have other sources or ideas?
I now realize that I should have bought many of these at the time.
Thank you! Lisa
Lisa
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** The reel does not house the cable. The cable connects to a flat metal tape enclosed in the reel. The reel mentioned at the top of this thread is a near exact copy of the orig. reels that came in the clam shell vehicles. I was not aware that the Pullman company ever made the cables. The reels are still available. | | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | Thank you - where do you find the ball and cable part? Thanx you
Lisa
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Danchuck cables for nomad 1955 1956 1957 CHEVY NOMAD TAILGATE CABLES , PAIR NEW ** USA MADE ** https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F152788602581 | | |
