2 members (Gray_Ghost, 1 invisible), 111 guests, and 3 robots.
Topics128,129
Posts1,056,697
Members48,454
My new project. Has 1954 235 with 3835913 head, Saginaw 338935 4 speed and open drive line. Can't get info from PO. Has like new 12 bolt rear end. rear end numbers 12345 lower 6x890 upper x= can't read. any idea if this is 3.07 or what? Thanks BIll
To determine what size gears you are running in the back, you can simply jack up the back end and rotate the gear driven wheel to see how many revolutions it takes to turn the drive shaft one complete rotation. This will give you an approximate idea.
Craig
