2 members (2-Ton, TooMany2count), 76 guests, and 2 robots.
Topics128,024
Posts1,055,393
Members48,422
#1280958 09/20/2018 10:20 PM
How can I tell what cubic inch size my engine is?
Is there a list available for 6 cylinder AD Chevrolet engine block/serial numbers?
If I had a reference would it tell what cubic inches the engine is?
Any help appreciated
Skinnedknuckles
1 1951 Chev Panel with a 350 small block, automatic tranny.
1 2004 Chev 2500 HD pickup... stock
1 1950 Chev 5 window pickup; 261 c.i. engine, 4 on the floor.
With lots of time and money, any Stovebolt can be restored.
"Is there a list available for 6 cylinder AD Chevrolet engine block/serial numbers?"
I think you will find that block/head casting codes (not engine serial numbers) to be of more use in IDing an engine?
Engine serial number/codes might get changed over the years, block/head casting codes do not get changed.
http://www.1954advance-design.com/Web%20images/casting-code-photos/low-press-codes-ser-nums.html
http://www.1954advance-design.com/Stovebolt-engine/casting-numbers.html
Thanks for the info Tim..... we can always count on you for great information.
JB
