| | | Forums66 Topics128,138 Posts1,056,751 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 27 | I am curious what type of covering would have originally been on the floor of my 1941 fire truck; I’m assuming some kind of rubber floor covering? | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | If it is the standard cab truck I am guessing it would be just the regular rubber floor mat that would have come with the truck from the factory. Jim | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I am curious what type of covering would have originally been on the floor of my 1941 fire truck; I’m assuming some kind of rubber floor covering? I have no idea if it is a custom open cab model. A 1941 standard closed cab truck had a rubber floor mat. Reproductions are available but I have not had good luck with their quality and would strongly urge you to avoid them. A very inexpensive alternate is to use 1/4 inch thick horse stall matting rubber material purchased by the foot available at farm stores. In the US, Tractor Supply is a good source. | | | | | Joined: May 2019 Posts: 8 New Guy | | New Guy Joined: May 2019 Posts: 8 | Vehicles of Victory has NOS Chevy 1 1/2 ton cab floor mats. Precut for the standard shift levers and parking brake. If you have an internal control for the PTO, you will need to notch it. $75 I believe. Jute or horsehair backing.
Why do we park on driveways and drive on parkways?
