| | | Forums66 Topics128,075 Posts1,056,003 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12805 02/14/2002 5:31 AM | Joined: Feb 2001 Posts: 12 Member | | Member Joined: Feb 2001 Posts: 12 | what is the value of a 58 235? | | |
#12806 02/14/2002 5:34 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | How many miles? does it run?
How much oil pressure?
how good is the compression?
Is it complete?
#12807 02/14/2002 6:05 AM | Joined: Feb 2001 Posts: 12 Member | | Member Joined: Feb 2001 Posts: 12 | dont know miles as far as running idoubt it complete pretty much xcept for manifolds parts have been takin off but i think i have most of them it was sitting in the back of my truck when i got it | | |
#12808 02/14/2002 6:47 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Around here a rebuildable 235 block goes for about $100, a little more if it's complete.
Fred 52 3600 69 C-10
#12809 02/14/2002 7:06 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | | | |
#12810 02/14/2002 3:06 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Probably about 300 henweigh,,,,
#12811 02/14/2002 4:16 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I am with Profitt, that is only worth its weight in iron. I see running 235's for sale all the time from guys that pull them out to hack their truck into a V8.
54 3100 with 235 62 flatbed dump C60 with 261
#12812 02/16/2002 5:32 PM | Joined: Feb 2001 Posts: 12 Member | | Member Joined: Feb 2001 Posts: 12 | | | |
#12813 02/20/2002 7:31 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | DON'T scrap it. Somebody out there may need one good part off of it. Post a for sale ad on the swap meet under parts for sale.
Professional Novice
#12814 02/20/2002 7:42 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I don't know about the weight, but I did learn that if you take a 235 to a machine shop and tell them that it's in the trunk of your Bonneville (in pieces) that they won't believe you.
