1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
#1280461 09/16/2018 8:43 PM
49 3100 w/216. Anyone have a good part number for a replacement paper air filter element to replace the copper mesh filter in the 6" air cleaner (not an oil bath filter)? Thanks
Ed
Forty9 #1280463 09/16/2018 9:11 PM
https://www.fleetfilter.com/filter/42373.html
This is from an old post.
I do not know if the dimensions are correct.
Forty9 #1280467 09/16/2018 9:25 PM
Ex Hall Monitor
Ex Hall Monitor
Forty9 #1280677 09/18/2018 5:14 PM
Y
yar Offline
Y Offline
Forty9,
I just checked the size of the Wix filter in my '36 PU air cleaner. It is Wix number 42373 and it is 6" OD and 1 7/8" tall. The OD perfectly matches the metal mesh OD and I slightly extended the stud height with a coupling nut so I guess the Wix is ever so slightly taller than the metal mesh. I made that conversion so long ago I don't remember the metal mesh height. With the lid on you'd never know I extended the stud length.
Hope this helps.
Ray
Forty9 #1280706 09/18/2018 8:47 PM
Thanks for all the help....looks like the WIX 42373 is the ticket. Thought it might be using the WIX size chart but it's good to hear from someone who has it in use.
Ed
Forty9 #1280740 09/19/2018 1:31 AM
Keep in mind, that filter is what goes on a riding mower with a much smaller cylinder displacement. Once it gets just slightly dirty, you won't have enough air getting to the engine. You can test to find out if it is dirty by listening to the RPM when you remove it. The stock air filter flows a lot of air even when very dirty.
Carl
Forty9 #1281082 09/21/2018 9:24 PM
52Carl- thanks for that input, I will keep an eye on that since I live in the desert.
Ed
Forty9 #1281116 09/22/2018 2:10 AM
You have some of the prettiest piles of dirt I have ever seen! Y'all sure do stack it high too. 5,000 to 10,000 foot high in places. smile
