| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | 49 3100 w/216. Anyone have a good part number for a replacement paper air filter element to replace the copper mesh filter in the 6" air cleaner (not an oil bath filter)? Thanks
Ed
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Forty9,
I just checked the size of the Wix filter in my '36 PU air cleaner. It is Wix number 42373 and it is 6" OD and 1 7/8" tall. The OD perfectly matches the metal mesh OD and I slightly extended the stud height with a coupling nut so I guess the Wix is ever so slightly taller than the metal mesh. I made that conversion so long ago I don't remember the metal mesh height. With the lid on you'd never know I extended the stud length.
Hope this helps.
Ray
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Thanks for all the help....looks like the WIX 42373 is the ticket. Thought it might be using the WIX size chart but it's good to hear from someone who has it in use.
Ed
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Keep in mind, that filter is what goes on a riding mower with a much smaller cylinder displacement. Once it gets just slightly dirty, you won't have enough air getting to the engine. You can test to find out if it is dirty by listening to the RPM when you remove it. The stock air filter flows a lot of air even when very dirty. Carl
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | 52Carl- thanks for that input, I will keep an eye on that since I live in the desert.
Ed
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | You have some of the prettiest piles of dirt I have ever seen! Y'all sure do stack it high too. 5,000 to 10,000 foot high in places.
