6 members (DadsFirstPickup, John Dlugos, Steelonsteel, fonz8261, MNSmith, Jon G), 101 guests, and 6 robots.
Topics128,120
Posts1,056,325
Members48,439
#1280218 09/14/2018 4:44 PM
Hey Guys, I'm sure this sounds dumb, but I jacked up the rear of my van to work on the brakes and noticed only one tire was moving at regular speed in gear. The other tire moved kind of sporadically and I was able to stop it with my hand. The 4.10 differential came out of a 69 Chevy truck. Is this OK?
1958 Chevy Grumman Olson step van
Non locking or limited slip (open differential) this is normal. The wheel with the least resistance will spin faster, same in the air as in the mud.
BC
1960 C60 pasture art
I was thinking that, but I didn't find the right info. Thanks!
If you hold one wheel stationary and allow the other one to spin free, the action of the spider gears doubles the speed indicated on the speedometer. When we used to do "on the car" wheel balancing, my job used to be to "drive" the vehicle at an indicated 30 MPH in high gear while the guy at the wheel used a clamp-on device to monitor vibration and attach the weights. It was very effective, as the entire assembly, wheel, tire, and brake drum got balanced all at once. The actual wheel speed during that procedure was 60 MPH. On front wheels, we used an electric motor driven wheel spinner.
You are old Hrl. wink grin
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Can't be, I've used that equipment & I'm not old, but that was 30 years ago!
BC
The trick is to not get wrapped up in your work...
