0 members (),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | Cleaning interior of nasty 30 years of dirt roads. Mice condos since 76 in the headliner when it was parked in the barn. 4 corners, header & mickeys condo hazmat madness photos. nasty,nasty and nasty!
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | wrenchguy,
That is just part of the fun. Someday you will look back at those pictures and realize that you turned your truck into something you are proud of. Good luck with the rest of your restoration.
Rugo
Steve Rugg 53 3100
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes, good luck with the nest of your restoration.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2018 Posts: 92 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 92 | Yes, good luck with the nest of your restoration.  "nest", play on words? Dirt, grease, oil and rust don't give me the heebee-geebees like mice nest do! not really doing a restore....more like cleaning up and running for fair weather enjoyment. thanks, mike
| | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Got a 49-3100 almost 2 years ago--If my wife ever knew about the nesting mice in cowls/headliner etc--all vacuumed at PO home. Now we keep peppermint oil in cotton balls, loseley wrapped with aluminum foil under the seat, in garage on shelves--in wood piles--they stay away.. Bill | | |
