1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | I've heard there's a way to couple up a SM420 to a torque tube rear end. Can someone provide some details on that? Thanks! Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If it was chosen as an option in the 1/2 ton. Prior to the extinction of the torque tube, about 54-55 right? Standard in 3/4 ton which used a short enclosed forward shaft and then open rear shaft. Info/parts in the regular parts catalogs. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Is the torque tube the same length for the 3 and 4 speed options in the 1/2 ton?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, as far as I know.. but I've never had a 1/2 ton. Some friends have swapped these transmissions in their 1/2 tons without issue. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is the torque tube the same length for the 3 and 4 speed options in the 1/2 ton? Yes - and, of course, they both use the same u-joint coupling assembly housing-cover. The rear "housing" of the enclosed drive-shaft SM-420 4-speed [1/2 ton only in 1954] is the bolt-on cast-iron end-piece for a torque-tube. The 3sp and 4sp u-joints yokes are different. If you have pre-1954, you should use a rear-of-transmission mount on the existing frame cross-member. A reproduction mount is sold by Classic Parts. https://www.classicparts.com/1947-54-Rear-Transmission-Mount/productinfo/79-204/
Last edited by tclederman; 09/12/2018 1:09 AM. Reason: added clarification in [...]
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Thanks! I'm asking on behalf of someone else who is considering a SM 420 swap for a truck that now has a 3 speed. Jerry
| | | | | Joined: Dec 2013 Posts: 784 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 784 | The '47 second series 3100 torque tube and transmission were a one year and done configuration. I believe the '48-'53 are interchangeable. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Even with the SM-420 4-speed, he'll still drive it like a 3-speed...that 7:1 first gear is not much good unless you're in a parade. Mike B  | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Yep, anybody who has ever owned one knows that- - - -some people just have to test the electric fence for themselves! Jerry
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Even with the SM-420 4-speed, he'll still drive it like a 3-speed...that 7:1 first gear is not much good unless you're in a parade. Mike B  As a recent convert from the 3sp to the sm420, There is that granny gear that is nice to play with but the best advantage over the 3sp is having the syncho on the (2nd) gear cluster, the gear you normally start out in. I hated to either have to make a complete stop to get it into first on the three speed. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Good Point sstock, I hadn't thought about it that way! Mike B  | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 |
My 1953 half ton had the SM420, liked it a lot. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Pretty bullet proof, but pretty noisy too but hey it is a kick @ss truck transmission that can take any abuse. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jul 2018 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 51 | I just swapped out my sm420 for a 3 speed. Just wanted to put my truck in original configuration. (the 4 spd was installed later in its life). I wanted to go back to the 3 on the tree. It is an easy swap. Like others have mentioned the u-joint/yoke is different. The mount for the pre 54 is used for either transmission. The torque tube end is the same as well.
The 1st gear on the sm420 is def not gonna be used unless in a slow parade or working on the farm. My sm420 was pretty noisy, I was shocked how much quieter my truack is now with the 3 speed.
The sm420 is HEAVY so be careful installing it, the 3 speed is LIGHT.
Good luck! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There is one other good use for the SM420 1st gear on a "normal" truck (one that does not normally need to get a real heavy load rolling):
Win the "Slowest [non-stalling] Truck Race" at trucker shows/gatherings: - set the idle as low as possible (no stalling is allowed) - you can get out of your truck and walk along side of it, while you talk with onlookers - they might have to end the race and declare you the winner, due to time constraints (if it is a 1/4 mile race course)
Two other good uses for an SM420: - safely pull a VW beetle out of a ravine without burning a clutch (done that) - drive up the side of a barn (almost tried that in an altered state-of-mind)? | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Even with the SM-420 4-speed, he'll still drive it like a 3-speed...that 7:1 first gear is not much good unless you're in a parade. Mike B  I use 1st coming into a car show. Looks like I have an automatic.😉 Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I pulled tree roots out when our front tree fell, using my SM420. And guess what that did.........it twisted the splined end of the TT driveline. I'll never forget that mistake. LOL. Here's a pic of it: [img] http://www.cmaynard.com/Truck/TwistedShaft2.JPG[/img]
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Wow, you found the weak link. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
