4 members (Youngin' Tut 59, Jon G, fonz8261, MickeyP), 113 guests, and 2 robots.
Topics128,132
Posts1,056,383
Members48,441
Hello, does anyone one have an image of position of this label inside the door? Thanks
54 Chevy 1/2 ton
Don't know if this helps but on my 49 3100 the ignition, door and glove box are all keyed the same.
Ed
54 Chevy 1/2 ton
On most AD trucks, the key code will be on the door lock. Pull the retainer out from the rear of the door and you should find it on the lock near the shaft that goes into the door latch.
Check this post: Key code
A few posts down in that thread is a post by walterhvogel with info on how to cut a key to match the code.
Posey,
Do you have a label, and do you want to know where to place it?
I do not know; however, where did you obtain a label?
This was what I was referring to in attachment.
