2 members (Gdads51, TexasA&M48Truck), 185 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#1279865 09/11/2018 6:50 PM
I've heard there's a way to couple up a SM420 to a torque tube rear end. Can someone provide some details on that? Thanks!
If it was chosen as an option in the 1/2 ton. Prior to the extinction of the torque tube, about 54-55 right?
Standard in 3/4 ton which used a short enclosed forward shaft and then open rear shaft.
Info/parts in the regular parts catalogs.
1952 Chevrolet 3800 pickup
---All pictures---
Is the torque tube the same length for the 3 and 4 speed options in the 1/2 ton?
Yes, as far as I know.. but I've never had a 1/2 ton. Some friends have swapped these transmissions in their 1/2 tons without issue.
---All pictures---
Yes - and, of course, they both use the same u-joint coupling assembly housing-cover.
The rear "housing" of the enclosed drive-shaft SM-420 4-speed [1/2 ton only in 1954] is the bolt-on cast-iron end-piece for a torque-tube.
The 3sp and 4sp u-joints yokes are different.
If you have pre-1954, you should use a rear-of-transmission mount on the existing frame cross-member.
A reproduction mount is sold by Classic Parts.
https://www.classicparts.com/1947-54-Rear-Transmission-Mount/productinfo/79-204/
Last edited by tclederman; 09/12/2018 1:09 AM. Reason: added clarification in [...]
Thanks! I'm asking on behalf of someone else who is considering a SM 420 swap for a truck that now has a 3 speed.
Former BMW Rider
Former BMW Rider
The '47 second series 3100 torque tube and transmission were a one year and done configuration. I believe the '48-'53 are interchangeable.
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Even with the SM-420 4-speed, he'll still drive it like a 3-speed...that 7:1 first gear is not much good unless you're in a parade.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Yep, anybody who has ever owned one knows that- - - -some people just have to test the electric fence for themselves!
Mike B #1279938 09/12/2018 2:28 AM
Mike B smile
As a recent convert from the 3sp to the sm420, There is that granny gear that is nice to play with but the best advantage over the 3sp is having the syncho on the (2nd) gear cluster, the gear you normally start out in. I hated to either have to make a complete stop to get it into first on the three speed.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Good Point sstock, I hadn't thought about it that way!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Leo Offline
Moderator
Moderator
My 1953 half ton had the SM420, liked it a lot.
Pretty bullet proof, but pretty noisy too but hey it is a kick @ss truck transmission that can take any abuse.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
I just swapped out my sm420 for a 3 speed. Just wanted to put my truck in original configuration. (the 4 spd was installed later in its life). I wanted to go back to the 3 on the tree. It is an easy swap. Like others have mentioned the u-joint/yoke is different. The mount for the pre 54 is used for either transmission. The torque tube end is the same as well.
The 1st gear on the sm420 is def not gonna be used unless in a slow parade or working on the farm. My sm420 was pretty noisy, I was shocked how much quieter my truack is now with the 3 speed.
The sm420 is HEAVY so be careful installing it, the 3 speed is LIGHT.
Good luck!
Frank
1948 5 Window Chevy 3100 an absolute rescue that is now back on the road
1953 Buick Super 1 family owned since new
1956 3200 Big Window
1985.5 Mustang SVO
1986 Mustang SVO
There is one other good use for the SM420 1st gear on a "normal" truck (one that does not normally need to get a real heavy load rolling):
Win the "Slowest [non-stalling] Truck Race" at trucker shows/gatherings:
- set the idle as low as possible (no stalling is allowed)
- you can get out of your truck and walk along side of it, while you talk with onlookers
- they might have to end the race and declare you the winner, due to time constraints (if it is a 1/4 mile race course)
Two other good uses for an SM420:
- safely pull a VW beetle out of a ravine without burning a clutch (done that)
- drive up the side of a barn (almost tried that in an altered state-of-mind)?
Mike B #1280113 09/13/2018 4:28 PM
Mike B smile
I use 1st coming into a car show. Looks like I have an automatic.😉
Don
Can’t begin to tell you how much I hate the name Stovebolt.
I pulled tree roots out when our front tree fell, using my SM420. And guess what that did.........it twisted the splined end of the TT driveline. I'll never forget that mistake. LOL.
Here's a pic of it:
[img]http://www.cmaynard.com/Truck/TwistedShaft2.JPG[/img]
Craig
Wow, you found the weak link.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
