I work on each unit in the cluster separately without removing the whole cluster of gauges. I want to get to the gas gauge. There doesn't seem to be much room behind the dash to do anything. Thanks
If your truck is 2nd series:
You cannot get to the fuel gauge without removing the cluster from the truck
Then you have to remove the amp and temp gauge first before the fuel gauge will come out
If your truck is not second series disreguared everything I posted
