3 members (Gdads51, gswbbc, Hotrod Lincoln), 142 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#1277222 08/21/2018 7:02 PM
ordering new springs front/rear for my 46 1/2 ton. Am wondering who you all have ordered parts from in the past. I am looking at springs from General Spring (generalspringkc.com). They seem to be priced better than most that I have looked at. Has anyone used their products before? They will be stock spring/spindle combinations. Anything I should look for in particular from a vendor? Thanks for the input.
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
I have used St. Louis Spring several times and have always been very happy with them and their products. www.saintlouisspring.com
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
' Offline
Ed ,
Try this spring company .
They sell springs made from original oem blueprints.
https://www.eatondetroitspring.com/
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Sir Searchalot
Sir Searchalot
I would definitely buy from a local company to save on shipping. These are not rocket science. Can't see getting bad springs from a spring company. You live in a well populated area. Gotta be good spring companies there. Don't worry about it.
bigedpa,
Check your PM.
Mike
1951 3100 5 window
I just bought mine for my 1953 from St Louis Spring. They are American made, and they claim that they are made from North American steel. Mine were quite a bit less money than same thing from Eaton. They also came with correct bushings already installed.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Here is another reliable source:
http://www.springsnthings.com/
What is the going rate for new springs? Considering a suspension overhaul on my 54 after the driveline is done
https://www.classicparts.com/1947-54-Leaf-Spring-Front-ea/productinfo/74-421/
https://www.classicparts.com/1947-54-Leaf-Spring-Rear/productinfo/74-422/
I think Jim Carter, Eaton, and ESPO also give quotes/prices on their websites.
Shipping costs might be different - check them out.
I think that my pair of rear springs from St. Louis spring were $158 for a pair. I thought that was pretty reasonable.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
