| | | Forums66 Topics128,134 Posts1,056,736 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | Hello all. I'm swapping out my OE 1942 Muncie 4 speed for a 58 Saginaw 3 speed trans. I plan to keep my original 3/4 ton truck rear end. Unfortunately, I've found that my pinion input bearing is badly worn. Thus far, I've tracked down the OE part numbers for the front (905306) and rear (125630) pinion bearings, but have only found the front bearing thus far. Does anyone have a good source for the 3/4 ton pinion bearings for the 1942 truck? If so, please pass along your source. Thanks in advance. Tom
Ghost Rider Little Egg Harbor, NJ 1942 Chevy 3/4 ton pickup, 1962 235, Offy intake, Fenton headers, Dual Carter YFs, 1984 T5 1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | Tim:
Thanks. Appreciate the prompt reply. All the best... Tom
| | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | Unfortunately, the Buick farm was out of stock on this bearing.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | This is where a GM ff 14 bolt becomes attractive in both price($150. Most places) and modern, selective ratios.
Ed
| | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | Ed:
Thanks for the recommendation. What I'm building is a period correct street rod, such as one of us (with limited funds) might have done in HS. I really want to retain my OE artillery wheels, and the stock look of the truck. The engine is a 1962 235 with dual Carters, Offy intake, Fenton headers, and dual exhaust. I'm in the process of exchanging the stock 1942 differential (4.55) with a stock 1955 1/2 ton diff (3.90). It bolts right into the 1942 housing with no mods (other than the rear U-joint, and driveshaft length). That will make my OE Muncie 4 speed a bit more "drivable". I'm also looking at replacing the Muncie with a 1957 Saginaw 3 speed OD trans. Looks like everything will fit but, I need to do some more research on the ability to retain the 1942 bell housing vs. the 1957 bell housing. Biggest issue there looks like engine/trans mounts, pedals, and clutch disk diameter. I'll look into the GM 14 bolt you recommended. Thanks once again for your input.
Ghost Rider
