10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible), 94 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
#1279846 09/11/2018 3:37 PM
So I got into a debate with a guy on putting grease on front spindles.
He said that you have to completely degrease them before sliding the hub on, I said you have to put put a light coat on to prevent rust.
The question is which of us is correct?
1950 GMC 1/2 Ton Long Box
228-Zenith carb- SM420-bendix brakes
Either is fine.
"completely degreasing" them is primarily to remove old grease and possible dirt.
If you then want to wipe a little grease or oil on them to ward off rust you may as well, no harm done.
1952 Chevrolet 3800 pickup
---All pictures---
