| | | Forums66 Topics128,085 Posts1,056,091 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 37 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 37 | I have a 1955 (1st series) 3100 pickup. I am having a difficult time trying to find the brass distribution block that fits on the rear of the master cylinder. It is a small rectangular block with approximately a 5/8" hole for a banjo bolt and a 3/16" brake hole that takes the flared end of a 3/16" brake line. Chevs of the 40s has one, but the hole is too small 3/8 versus 5/8. part # is 3696540 if that will help with the description. Can anyone help me locate this part? Thank you! | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Try a NAPA dealer, one that has a franchise and deals a lot with street rod builders. Some owners run the business themselves and have help that know how and where to look for parts and some might even have the part on a shelf. Their parts might be a bit more expensive than a bigger store, but from my experience worth the little extra cost when the need arises.
