7 members (mason86, 55shaker, Paul Mullen, Peggy M, walter74, Bill Hanlon, Hotrod Lincoln),
62
0
Mod | | | Forums66 Topics128,050 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12797 06/04/2002 7:21 PM | Joined: Dec 2001 Posts: 15 New Guy | | New Guy Joined: Dec 2001 Posts: 15 | I've got a newly rebuilt rochester 1 barrel that has about 500 miles on it. It looks like it is leaking from around the shaft of the butterfly valve, but I am not 100% sure. Anybody had this problem and know how to fix it? Where else might it be leaking from? All of the external srews are snug. Thank you in advance for any help. | | |
#12798 06/04/2002 8:55 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A well-rebuilt Rochester will often have bushings around the shaft for the throttle butterfly valve (a common point for wear and leaks).
The gasket between the top and the main body also seems to be an opportunity for a "leak". The gasket acts as a wick. However, I am not sure if this problem is a result of a poorly adjusted float. I recall reading that it is not uncommon for the top to warp a little and thus allow a little seepage at the gasket.
Tim | | |
#12799 06/04/2002 9:53 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Curt; Had the same problem on mine. It had an electric fuel pump installed at the time. Took that out and put in a new mechanical unit. Still leaked at the carb. Read somewhere about installing an inline pressure regulator on the fuel line to the carb. Got a pretty chrome one at the local auto parts store with a dial-in gauge on top. Put it inline with the carb and set it for 2.5 psi. Works like a champ and looks pretty too. Think is was made by Puralator. | | |
#12800 06/07/2002 3:33 PM | Joined: Dec 2001 Posts: 15 New Guy | | New Guy Joined: Dec 2001 Posts: 15 | Thank-you men for your help. I've got about a week left on my carb warrenty and I actually found the receipt, so I am gonna have it replaced for free, I hope. If I have any more problems I will probably go with the pressure regulator as suggested. Thanks. | | |
