| | | Forums66 Topics128,091 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Good afternoon. Quick question. I'm confused as to which terminals are which on my 1952 3100. The assembly manual pictures don't really seem to match the switch I have and even it one of them is, they indicate one of the outer terminals for battery. On mine, the middle terminal has a B stamped on it. I would assume that is for the battery? If so, is it safe to assume it doesn't matter which terminal goes to high/low since you are just toggling through them
Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Your switch matches the one on my '38. The hot wire from the headlight switch connects to the center lug. If the switch fits the holes and works, use it. You are correct that it's a simple toggle. If you have a battery and a spare light socket it's easy to test which lug is which. On mine I used the top lug for high beam and the bottom for low beam.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It is useful to obtain a simple VOM to answer questions as this and others, instead of guessing or risking making smoke.
Ed
| | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Your switch matches the one on my '38. The hot wire from the headlight switch connects to the center lug. If the switch fits the holes and works, use it. You are correct that it's a simple toggle. If you have a battery and a spare light socket it's easy to test which lug is which. On mine I used the top lug for high beam and the bottom for low beam. Thanks Tiny! Ron and Ryan Hill 1952 Chevy 3100 | | |
