6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#1279461 09/07/2018 10:43 PM
How could one determine HP, with a rebuilt engine bored over .40, Fenton Headers, 848 rebuilt head with new rocker arms and shafts. Weber 32/36 carb with heat from Radiator. Need anything else--Thanks Bill
Just do what everybody else does- - - - -lie about it! To get an accurate reading, you'll need a dyno.
Horsepower = torque X RPM divided by 5250.
Then you'll need to dial in a correction for ambient temperature and humidity. On average, the correction factor reduces the raw HP figure by 5 to 7 percent. There's a computer simulation program called "Desktop Dyno" that seems to be pretty accurate. I've done a few fantasy engine builds with D/D on small block Chevy engines, using the same parts specifications as ones I've actually built and dyno'ed, and the numbers came out close to equal for the real thing and the computer simulation.
